T & M Sinfonia No.7 Full Range Speaker
T & M Sinfonia No.7 Full Range Bookshelf Loudspeaker is available now. These are the specification of the speaker:
* Audiophile graded Mark Audio Alpair 7 4” Full Range Driver (gun-metal grey color)
* Sensitivity: 88 dB
* Impedance: 4 ohms
* Frequency Response, 40Hz~30KHz
* Power Handling: 40W (peak)
* Cabinet designed by Mark Fenlon, Bass Reflex bookshelf, made by 20 mm Real Oakwood
* German Sommer AWG16 LSP-performance Speaker Cable as internal wire
* High Quality Binding Posts and Professional Damping Foam
* Dimension: 200W x 245D x 310H mm
* Assembled in Hong Kong
Promotional Price: USD339/pair
The price is for complete products and not include shipping cost.
Details of Alpair 7 driver, see:
http://www.markaudio.com/alpair/7
The Alpair 7 is a rare (possibly unique) driver in this size and class. Its primary feature is its extended high range. Operating to 30kHz the Alpair 7 eliminates the need for a tweeter. The driver achieves this performance without using a whizzer or co-axial centre tweeter. The Alpair 7 is a purist single cone/cap design.
This driver incorporates a new cone multi-forming technology originally developed in Japan. The cones are made using 7 separate forming and trimming processes, all controlled via CNC operation. The accuracy of this technology is superior to conventional spun and press methods.
Hello,
The new price for T & M Concerto No.7 full range speaker in 2011 is US$389/pair as the cost for material of cabinets and exchange rate between RMB and HKD increased.
I will quote the shipping cost to you later.
I need to install Alpair 7 drivers into the cabinets if you confirm to buy. I have stock of Alpair 7 in gold which is upgraded version for the frame and seal.
Thanks & Regards,
Tony.
Is this price still valid? and whats the price on a pair of these shipped Los Angeles California(US)? And are they ready to go and is the drivers the 2nd gen 7's and do you have them in gold?
Mark Audio Alpair 7 Gen.3 drivers are available now. This is the birch plywood version.
* Audiophile graded Mark Audio Alpair 7 Gen.3 4” Full Range Driver (champagen and gun-metal grey colors)
* Impedance: 6 ohms
* Frequency Response, 40Hz~32KHz
* Cabinet designed by Mark Fenlon, vented bookshelf box, made by 18 mm Finnish birch plywood
* Sound from Heaven President X speaker cable as internal wire
* High quality binding posts and professional damping material-fibre glass
* Box Dimension: 196W x 242D x 306H mm
Promotional Price: USD370/pairThe price is for one pair of fully assembled speakers and not include shipping cost.
