T-Amp - Metallic/tinny sound ?
Hello, I am on my second Dta-100a Tk2050 amp and while I think it has a great mid range I notice that acoustic guitar and cymbals have a metallic-grainy-tinny sound... hard to describe. I dont notice it on vocals. It is somewhat subtle but enough to be annoying. Its not on all tracks, but many. I'm wondering if this is common with these amps? Isnit a matter of breaking in the amp? Ive tried different speakers, different sources, and exchanged my first dayton but they are both the same.
Could it be the fact that the dayton is a cheap amp? Lots of people still rave about these. I would be willing to try to build a better amp as I like the sound otherwise. Any ideas?
Maybe you are now able to hear for the first time, how your source/dac sounds
on cymbals? Other amps have smoothed the sound. Try different sound sources.
MrTrout, I have seen your set up on you tube and it sounds good from what I can tell.
Besides changing the power supply for a better one, Would it be possible to build some kind of rechargeable battery power supply? I notice Red Wine Audio does this, but I dont know what voltage/current would be best and safe.
Im hopping to get a good sound from a t amp to avoid having to buy a NAD for 400 bucks 🙂
BTW- Source and speakers make some difference. I am using the amp with a pair of paradigm atoms and an audioengine D1 DAC. But no matter what the amp is attached to ( speakers/source) I experience unpleasant distortion mostly in the upper range.
Seawalker, your problem with the high's is definitely not your Audioengine D1 DAC. I have some concerns about the the Dayton DTA-100a amp.
See this review: [Review] Dayton Audio DTA-100a - Class D integrated amplifier - [English]
The internal photos of the DTA-100a leave a lot to be desired in terms of workmanship.
I realize it is an $80 50wpc amp, but I prefer spending more money on a higher quality unit like the Topping TP60:
TOPPING TP60 TP-60 & TA2022 T-Amp & 2X80W & STEREO AMP | eBay
The internal photos show high quality components and assembly.
So I did a bit more experimenting with the Dta-100a.
For a power supply I hooked up 2 12v lead acid batteries in series. Both batteries were 12 amp hours each. I noticed a very slight improvement in sound quality, mostly better dynamics. Not as major as I thought.
I bought a NAD 316 Bee to compare. The NAD sounds surprising close to the Dayton! The NAD did smooth out the rough treble of tambourines cymbals and the like. But did not have the sweet mid range of the dayton.
I think the issue that im noticing is the real transparency of the T amp combined with some less than stellar recordings (some flamenco guitar artist I listen to don't always have good recordings), and my speakers titanium tweeters. I do not hear this distortion on a pair of M-Audio studio monitors that I had.
I did try a Topping TP20 which gave me even worse sound than the dayton but probably because its power is much lower.
Id like to maybe put together my own T amp like the Helder HiFi monoblocks or Sure tk2050 with a better power supply as long as I can add a remote control motorized pot and stay under 200 bucks.
I purchased the 4ch 100 watt Sure tk2050 a while ago and spent considerable time auditioning it against a TA5630 based amp and a Sonic Impact 2020 based amp. The Sure amp sounds fine at low levels but turn it up and every thing becomes unbearably shrill and artificial. Maybe this chip has been better implemented by other manufacturers but at 40 watts output it produces one of the worst sounds i have experienced in my 30 years in HIFI. The above mentioned chips particularly the TAS5630 are better!
I just purchased a pair of PopPulse T-150 Pro tripath amps and I couldn't be happier. These TA2022-based amps are connected as 150wpc mono blocks. You can bypass the voume control by moving a molex connector and a switch on the board toggles to mono block. I chose this pair of amps after reading reviews and preferences of the TA2022 over other chips for overall sound quality. I am feeding 88dB Merrill full range drivers mounted in custom bass reflex cabinets (2-inch port) built by Fritz Heiler. The sound is amazing; friends think I have a sub woofer and the mids and highs are very accurate. I do not have firsthand experience with the Sure tk2050, but I do firmly believe tripath amps are best suited for full range driver speaker systems. In my research of various tripath amps I have noticed that quality of internal components is not very consistent. That is why I have stuck with Topping and PopPulse. Although it is an e.bay ad for the UK, here is a link that shows photos and specs of the PopPulse T-150 Pro:
Pop Pulse T150 PRO TA2022 Class T amplifier - UK stock!! | eBay
