Hello, I am building a SET utilizing a 3C24 tube and Monolith output transformers. There are different connections for 4/8/16Ω outputs. I'd like to be able to switch between the different taps. I'm planning on individual binding posts but want to switch the different connections shown below.
I want to use a single throw/triple pole switch so as to change the connections for the 16Ω wiring shown.
A to C will be on one pole (one side of the "throw")
B to D will be another pole ( same as above)
B to C will be on the third pole on the other "throw"
My question is will the Carling Miniature Switch be adequate for the task. The amp will put out about 5-6 watts and the switch is rated for 5A@125VAC or 28VDC.
Is there a better solution?
That's fine, the switch will only conduct around 1A or so at most, on peaks.
Just avoid the R gold contacts (the letter just before the final E in the part number),
which have no silver.
The ones I have are silver over copper on the movable contact and silver over nickel on the terminal side. Thanks!That's fine, the switch will only conduct around 1A or so at most, on peaks.
