Switch inside O/S D100?
I just received a Soundstream D100 (series 1). I pulled the cover (as I do with all my amps when I get them and I'll bet I’m not the only one!) off to see how things were looking and there is a switch (not dip, a real switch) but does not have any pop plug in the bottom cover to access (Odd they would make you take the amp apart to swap stereo-mono).
What does the switch do.....stereo-mono? Impedance optimization?. Its not listed on the board.
Thanks for any insight
-JH
You can see the switch in the middle near the terminal block speaker outs.
-JH
Secondary ground lift - in case of noise: flip switch.
