swap dome tweeter for ribbon?
Hello all, I have a pair of Tyler Acoustics Taylo Reference monitors:
Taylo Speaker Line
I am curious about swapping the existing tweeter for a ribbon tweeter. I really like the ribbon sound, and I'm wondering about the feasibility of a swap.
The Taylo Reference use the ScanSpeak Revelator. Specs and photo here:
https://www.madisound.com/store/product_info.php?manufacturers_id=148&products_id=914
I'm cusious about swapping them out for Mundorf AMT2310C. Specs and photo here:
https://www.madisound.com/store/product_info.php?cPath=45_229_236&products_id=8803
Not knowing much about crossovers, I'm wondering if there are other modifications that need to be done? Or if just a straight swap out of the tweeters is all that is needed? Can any of you crossover / tweeter guru's comment?
Both look to have similar 91 db/W sensitivity, and similar 2000 Hz recommended crossover frequency, so it should just be a straight swap, no?
Thanks everyone.
let us know what the cross over is made of,
(show us a picture)
that will make this alot easer .
i's suspect that
AIR MOTION TRANSFORMERs
ought to be able to work in this sort of swap .
have to see the crossover first ...
