I was wondering, in those surround satelites using 2" or 3" drivers and a small tweeter in a 5 inch by 3 inch by 6 inch box, I guess you really dont want to give them frequencies lower than 150hz.
that means you need 2 high pass crossovers (or one bandpass) , one for the mid and one for the highs.
for the highs. aint too bad, basicly just a cap will be fine, but for the mids......
If you do a highpass at 150hz for the mid, and wanna go polyprop caps, that would be a HUGE cap! 132 uF if the driver is 8 ohm.
If you go with electrolytic caps, the size would be reduced, but still, for a box that size, its quite big.
And if you do a band pass first order for the mid, its a 132uF and a
coil at 4khz for eg.. thats ever more parts..
and unless the walls are about 1 mm thick, I dont see how anyone would put all those parts in a casing that small.
Even worse, Ive seen systems like this one, where the subwoofer is using a 80hz lowpass..
Pls dont tell me those satelites can cover from highs to 80 hz....(whitout extreme xmax mids, wich will make distortion higher...)
I was just wondering.....
I've been thinking in the same direction.
My problem is matching the rears to the fronts. In my case those are a pair of B&W 330i's
hum, I think 5.1 receivers should have a active highpass at every channel, like from 0hz to 100 hz that would be user defined and to be able to turn it off.
I'm ready to pay the 10$ more (if thats how much it'll cost them to make that per receiver)
that way the mid/bass in satelites would need only a small low pass and the tweeter would need a simple highpass
