Sure TDA7498 Build Question
Ok, so today I pulled the trigger on a Sure TDA7498 2-Channel Board (100 WPC @ 6 Ohms), Sure P/N AA-AB32189.
My question is regarding the power regulator: Should I go with a simple off the shelf 36VDC Regulated Power Supply, or will I benefit from going with a different Power Supply setup? Maybe a PS board and a Toroid Transformer?
The amp will not have a volume pot, as it will be controlled by my Pre-Amp.
