I ordered a SI Super T-Amp after reading the rave reviews all over the net and the remarks on this site. I'm totally new do the DIY Audio scene. I have some experience with car audio and even more with computer hardware. I like to build things and break things and put things back together.
That said, I've read the FAQ and tried doing some searching. I see that everyone replaces the stock power supply:
Where do you buy them? Does Radio Shack carry these?
The FAQ also meantioned a DIY Mod FAQ on the way. How is this coming?
A list of terms with descriptions and pictures would be great.
I know you guys must answer questions over and over the same way I do on other forums. Please bear with me.
What size power supply do I need?
At least 12 volts, 1.5 Amps. It is best not to run the Sonic Impact over 13V, and a heatsink is a good idea at that voltage. The 41Hz AMP6 has a built in power supply. A 3 to 5 amp regulated supply is plenty. The amps typically draw about 300mA with a musical signal.
