Sunvalley SV-S1645 - 45 Tube Amp - Available NOW
I use plate to plate feedback in all my builds and I will never go back to not using it.
Both Moglia and Broskie have discussed the merits of this type of feedback.
https://www.tubecad.com/march2001/
Feedback can deliver some amazing things: lowering / eliminating noise in the driver stage and lower output impedance.
Lots of people summarily dismiss feedback without ever having heard it done properly.
Reactions: zettelsm
It is on the way from Nagoya, Japan to Vancouver , Canada
SV-S1645D Specifications
Power Output: 3W+3W(8Ω, THD10%)
Frequency Response: 10Hz~100kHz(8ohm, -3dB)
Gain: 28dB(8Ω, with first stage ECC81)
Noise floor: 0.5mV(8Ω, input short)
Power Consumption: 0.8A(115V), 0.4A(230V)​
Power Output: 3W+3W(8Ω, THD10%)​
Frequency Response: 10Hz~100kHz(8ohm, -3dB)​
Gain: 28dB(8Ω, with first stage ECC81)​
Noise floor: 0.5mV(8Ω, input short)​
Hi Victor do you have any other pictures which show the space around the Blue Alps potentiometer. It would be nice to be able to have had room to fit a higher quantity option with out needing to slightly reposition the nearby components.
Best wishes for the New Year
Jamie
