This is the permanent solution to get rid of the cell phone interefence of the the driver tubes (EF37A).
This noise shielding is effectively reduce the interference.
SV128ii is one of the best amps from Sunvallery. There are two versions 15W or 25W with KT170.
It has a crystal clear and powerful sound.
Finally I have the proper speaker to match SV-128ii
SV128ii can drive Stenheim 2.5 to the best of my knowledge...
I will demo this combo in the Florida show...
Hi Victor,The is the best power sound power amp from Sunvalley..
I know there is a drastic difference in power between the Sunvalley SV-S1645D and this amplifier. And I'd suspect there is a difference in sound character between the two. Can you characterize how the SV-128BII sounds compared to the SV-S1645D?
Thank you,
Steve Z
Hi Steve
SV128 is one of the best amp from Sunvalley. Yes SV128 has 15w or 25w output power.
If I want to demo my my 2.5 speaker I will use SV128ii. SV1645 is my daily amp.
I perfer to listen in very low volume. This is why I prefer SV1645.
In exhibition, I must use SV128ii.
You will love both SV128 and SV1645
