Suggestions for fitting a replacement tweeter to yamaha NS-777
I blew out the tweeters in my yamaha-777.
1) Could you guys suggest a replacement(I'm guessing a vifa 6ohm tweeter will be an ok substitute)? Matching yamaha tweeters can't be sourced anymore
The tweeter is a attached to a plate that screws into this plastic faceplate
The back of the the plastic piece looks like:
The tweeter and the mounting plate look like this
Measurements are all in millimeters.
2) Will I be able to get a tweeter that is a drop-in replacement? If not, what is the best way to mount a replacement tweeter?
