Subwoofer guide posted, Sealed Dayton 15" DVC
Ahhh you used that sandwich design to isolate the panel vibrations from the outside of the enclosure.... I am still wondering if it is possible to tell the difference in the sound between a normal enclosure built from one layer of 3/4" mdf with bracing, and the sandwich design with liquid nails or foam rubber and an external box. How does it perform? Can a penny be set on the top of the enclosure on end with the sub running full tilt without the penny falling?
