My front channel diy's (mark II) are nearing completion.... and my thoughts turn to 5.1/DTS etc etc
When I get my DTS decoder, my stereo receiver will be surplus....
question
Can I then use this as a subwoofer amp instead of using a plate amp??? would represent a nice saving if I could.....
cheers
lee
question
cheers
lee
I have zero ideas as to what a DVC sub is.....
my question is, can I build a diy sub without a plate amp, but use a normal amplifier instead, ie mounted remote to the sub..... I fairly sure I could - is there any reasons as to why I can't do this......
DVC = dual voice coil..
means you can connect left and right outputs to 1 speaker...
I'd probably go for 2x 10" or 2x12" using both channels of your spare amp..
You'll be using your D.D processors sub crossover, so the only thing you'll miss by not having a plate amp is the variable phase knob....TBH, it makes no differnce on my sub(in my room🙂 ), and you've always got the option of swapping the speaker leads to go 180 degrees out of phase...
I say go for it!
Rob
I say go for it!
Rob
I gather that I could also just use one of the amps channels also and build a standard one driver sub???
cheers
lee
cheers
lee
Xiph0id said:I not famaliar with your amp's construction but to be safe I would not use just one channel.
why not? 🙁
SkinnyBoy said:
why not? 🙁
I dunno, my brian farted I guess, because he right it's ok.
You might be concerned with power output thought, depending on whether the amp shares it's power supply or not.
plasmodium said:I gather that I could also just use one of the amps channels also and build a standard one driver sub???
cheers
lee
You could, but using twin drivers would gain you 6Db output, which is huge in a home cinema environment(where you need big, clean spl's) ie, at a given spl, the twin unit will be using a quarter of the power of the single unit..unless your stereo amp is a 400 watter you'd be better off using 2 drivers...
http://www.diyaudio.com/forums/showthread.php?s=&threadid=7455&highlight=doubling+drivers
hth
Rob
I have a single shiva with DVC that i drive with the 2 channels from one of my NAD7020s. Works fine.
dave
- Subwoofers
- subwoofer amp
