Hi.
Anyone have a nice design for a 100Watt subwoofer amp?
I've alreadt built a nice active low pass with adj freq. My power supply will be about +/- 39V when fully loaded with a 4ohm speaker. My heatsink that I have already "ready-ed up" will be able to take 4x T0-3P style cases.
Just wanna build something thats gonna last! must be simple to build. discrete would be nice.
P.s there is no space for a fan!!😛
There must be at least hundreds of built and tested 100W into 4r0 amplifiers on this Forum.
Join a thread and get a feel for how that particular choice works out. If the feedback is not to your liking, choose another.
A 100W into 4ohm? The world is your oyster! 😀
This thread might help:
http://www.diyaudio.com/forums/solid-state/100907-st151-100w-amplifier.html
However, your requirements to use an existing power supply and heatsink does narrow down things a bit.
Regarding the OPS, the first thing that comes to mind in a TO3 case is the MJ15003/MJ15004.
The 39V PSU rails are good for 190W into 4 ohm. In theory at least. What is the VA rating of your transformer? Will the speaker unit(s) that you have in mind handle it?
No it won't. Not in theory, nor in practice.The 39V PSU rails are good for 190W into 4 ohm. In theory at least.
You can expect 100W to 120W into 4r0 from your +-39Vdc PSU.
