Substitution for 2SA1360/2SC3423
I'm having trouble finding a good replacement for these obsolete transistors. They are predriver transistors in a Phoenix Gold SA3.0x. I am thinking of using 2SA1964/2SC5248. I know the pinout is backwards, but they are the closest match I have in stock. Are there any better options available?
Thanks,
Jason
Thanks,
Jason
2SA1381/2SC3503 which is used by many amplifier in this forum.
The complementary PNP transistor to the 2SC3423 is the 2SA1360.
Replacement and equivalent transistor for the 2SC3423
You can replace the 2SC3423 with the 2N5655, 2N5655G, 2N5656, 2N5656G, 2SC1565, 2SC1565A, 2SC2258, 2SC2481, 2SC2688, 2SC2690A, 2SC2704, 2SC3335, 2SC3416, 2SC3417, 2SC3502, 2SC3503, 2SC3600, 2SC3601, 2SC3788, 2SC3789, 2SC3790, 2SC3955, 2SC3956, 2SC4212, 2SD1609, 2SD1610, BD127, BD128, BD157, BD158, HSD1609, KSC2258, KSC2258A, KSC2688, KSC2690A, KSC3502, KSC3503, KSE340, KTC2800, MJE340, MJE340G, MJE344 or MJE344G
2SC3423 npn transistor complementary pnp, replacement, pinout, pin configuration, substitute, marking C3423, equivalent, datasheet
Replacement and equivalent transistor for the 2SA1360
You can replace the 2SA1360 with the 2SA1021, 2SA1144, 2SA1220A, 2SA1322, 2SA1352, 2SA1353, 2SA1380, 2SA1381, 2SA1406, 2SA1407, 2SA1478, 2SA1479, 2SA1480, 2SA1540, 2SA1541, 2SA795, 2SA795A, 2SB1109, 2SB1110, HSB1109, KSA1220A, KSA1381, KSE350, KTA1700, MJE350 or MJE350G
