Substitute for 2SC3421/2SA1358 Drivers
These will be driving NJW0281/NJW0302 outputs on a 70 w amp. The original outputs were Sanken 2SC3855/2SA1491, bdent has them, but not in matching hfe groups, so I'm going with the ON Semi subs which look quite good. Would BD139/BD140 be my best match here?
the 1358 is quite a nice driver.
There are literally hundreds of alternatives out there that could be substituted.
If the amp has low voltage supply rails then you might get away with the bd, but they are not equivalent. I would not use them.
The unit in question is a Denon PMA-520, the schematic is here:
4shared.com - document sharing - download pma520.pdf
It is suitable for 6 ohm speakers and sounds surprisingly good. I am currently using it with Snell KIII speakers, have had NHT and Paradigms on it also, always have been pleased. Not "high end", but most definitely among the better commercially available amps I have heard.
Check that rail voltage.
70W into 8r0 and +-50Vdc does not equate, unless they have made so many price cuts that they have ruined the performance.
Think what higher voltage smoothing caps and a smaller size power transformer will do for the total shipping weight.
Not much 🙄 , one has to keep in mind these are mass produced amps, the same transformer is probably used in higher wattage amps of denons range, bulk purchase keeps the price lower, this applies to the caps as well.
I only sell a amp here and there and this works for me too, plus I have the added benefit with clipping performance. For a diyer only building a amp for himself it doesnt quite equate price wise but I prefer it to using clipping enhanching circuitry which to my ears has always degraded sound quality.
The Vceo of the originals (2SC3421/2SA1358) is 120V. The Vceo of the suggested replacement (KSA1220/KSC2690) is 120V. The rails are indicated as 50V on the schematic. Is this not good enough? Bdent has originals, but they would not match hfe group, I'm assuming is the case, have not gotten back to me yet.
You cannot specify the Vce0 of the drivers until you know what voltages they have to operate at.
Measure the PSU first.
