sub specs
staaaaaaaaaaaaats
Are you talking about buying sub and box, or making a box for a sub? if your buying the lot, i suggest Ebay and looking in some shops, and maybe the trader and a few op shops, though op shops dont often have 12 inchers. if you are making or buying a box for a sub you have - - -
we need much, much more information
all the thiele small parameters you can get on the sub, the room size, the frequency bass you want it to play, how big/small the box can be for convenience, what sort of wood you can use, etc
i suggest using WinISD to calculate it.
http://www.linearteam.dk/
if you dont understand it, just tell me as much as you can of what i wrote above.
also what is your budget? it could be an issue. and the timeframe. can you make it well yourself?
-Eli
RIP MY HIFI AMP :bawling: LEST WE FORGET
(unless skinnyboy can fix it)
