STUDIO 350 PAIR
This listing is for a PAIR of famous silicon chip studio Power amplifier fully build and tested !
We re-design the PCB with extra ground to give that added effect
PCB size 240mm X 100mm, Thickness 1.6mm with Gold / Black under - surface finishing
All mounted components from reputed Electronics suppliers Mouser, Digi-key and Element-14. Resistors / capacitors used are military grade Low-noise DALE
We use CONRAD heat sinks with a Neat finish
Tested and Bias with Rail voltage /- 70
world wide shipping available
If 1 Kv transformer needed to be built for your stereo that can be done for an extra cost. Enquiries - cpg@rfwaves.com.au / 0406288952
