I am building a simple one 6688 tube per channel headphone amp. It was working fine on test board. When I put it into a wood frame case, there is vey loud hum from one side. It is not bad tube or wiring mistake. It plays music fine on both side and tube roll does no help. But when I put my finger on the tube, the hum stops. I guess it is oscillating on that side. I need to get my scope out tomorrow to check it. Or maybe it is a loose tube socket? Before I change the socket, I want to see if anyone has had similar experience.
Thanks.
Thanks.
Try putting your finger down onto the chassis next to it to see whether the vibration isn't coming through from the power transformer.
induction maybe?
Hi
I just finished a phono preamp based on 2 6688 stages in triode mode and it hummed more than a bee hive in spring time.
based on my experience that might be some form of inductance in the amp. If you touch the tube and the metal chassis does it go away?
Is it possible you arent using a star ground pattern?
let us know how you go
Nick
Hi
Nick
It turned out be due to bad tubes. Now it is dead quiet.
With the bad tubes, the amp will start or stop hum when I move my fingers near the tube without even touch them.
