Some strange thinks occur with my 300B filament supply. This is the schema: http://www.homepages.hetnet.nl/~rjonkers/psu.gif (one from the bottom).
1) Startposition: If I adjust R11 to deliver exactly 5.0vDC the circuit draws 1.41A. The 300B filament is grounded via the '-' of the DC supply and a 10R resistor (fixed bias circuit: http://www.homepages.hetnet.nl/~rjonkers/amp.gif ).
2) If I connect the 300B filament to ground with two 100R series resistors, the circuit only delivers 4.7V so I have to re-adjust R11 to get it back to 5V. Voltage drop over R12 is 1.5A, so for some strange reason the 300B's start drawing more current. How is this possible?
3) Back to startposition. If I don't connect the B+ of the 300B's right away in order to heat them up first, the circuit only delivers some 4.6V and never gets to 5.0. If I connect the B+ the normal 5.0V is delivered. Now the main issue, if I use a LM350 as a current source and set it to 1.41A why doesn't it deliver 5.0V without the B+?
Ralph
Ralph
MR. OHM.
Well of course the 100R resistors will cause a voltage drop and the circuit will draw more current.
Yes...that is to be expected.
Cheers,😉
Cheers,😉
AFTERMATH.
There is no point whatsoever in using a current reg for tubes that aren't specified for that.
BTW...why not leave the heater floating iso grounding it?
Cheers,😉
Cheers,😉
Thought there were some sonic benefits so I use a current source for both the 5687 and the 300B. Are BOTH those tubes not 'specified' for that?
Don't know about floating, I think they are. 5687 supply is only grouned via pin 8 of the 5687 and the 300B supply only via the '-' pin of the 300B's supply. But please remember that you are 1000 steps ahead of me 😉 so I may not understand you correctly.
ACHTUNG.
Correct.
What I mean is that you don't "have" to reference the heater to ground...quite often you will be injecting ground currents back into the circuit by running it that way.
Give it a try,😉
Correct.
Give it a try,😉
You mean this I think http://www.zwengelamps.com/heater.html , correct? Will try, thanks for the suggestion.
PROBLEMS IN PARADISE.
With cathode bias, you mean?😉
Cheers,😎
I think there could be some problems leaving the heaters of DHT's "floating"
Cheers,😎
dhaen said:I thinkthere could be some problems leaving the heaters of DHT's "floating"🙂
I'll say there's a problem. They won't work! The filament in a DHT, since it is the cathode, cannot be isolated. It must be referenced to B-, C+, and possibly chassis "ground" if it's the same as the other two.
I would also suggest that the output voltage should not drop with such a small change of load, with a voltage regulator...
REGS.
Wasn't that a current reg. he was using?
Cheers,😉
Cheers,😉
You all confuse me now. Can I change the 300B filament circuit to +40v and +45v with my fixed bias circuit or not? 🙂 Same for the 5687 circuit ofcouse, with +40V and +52.6V
Ralph,
All your questions are answered in this thread. I just confused it a bit with my comments.
If there is any particular post that you don't understand, just ask.
PS I think most of us are unsympathetic with messing with heater supplies
John,
I don't understand this. At this moment I use (just measured it, all relative to ground):
5687: +6.17v and -6.39v
300B: +6.34v and +1.31v
now I want to elevate both circuits approx 40V. Is it OK to try?
Ralph
Ralph
A MAN WITH A CONSCIENCE.
What you've understood so far still stands.
Huh?
No heater, no sound.😉
Huh?
Ralph,
In the case of the KR300, it is already elevated by the cathode bias.
On the 5687, you can if you want, but I see no reason to.
In the unlikely event of emission from the heater to the cathode, you'd only have to raise the heaters a few volts to stop it.
I really think your time and effort would be better spent in perfecting the layout and earthing scheme of this magnificent amplifier.
_____________________________
Frank,
"Messing" implies making unnecessary changes to an already working system😉
Strange, your understanding of English nuances is usually better than mine....
Frank,
- Tubes / Valves
- Strange filament behavour
