Strange Experience with NE5532
Hello everybody!
I recently met with a strange experience with NE5532 dual opamp.
I have got these opamps from Phillips as well as Texas Instruments.
The problem is that when these 2 half opamps are cascaded to form 2 non- inverting stages the opamp from Texas starts severe oscillations whereas Phillips make doesn't show any sign of oscillations.
CAN ANYONE TELL ABOUT THIS BEHAVIOUR?
With Regards
AmpMAN:smash:
hi ampman
try the decoupling i think it may fail
it could be the pcb layout , but cannot think how the philips worked and the texas didnt
is it heating up too much ? or spurious wave forms are being generated (tracked by your scope)
neways take care
suranjan
Vek said:
You didn't mention the gain settings in your circuit, but as far as I know NE553x are only stable for v>3, although Mr. Self states that the 5532 is internally compensated for unity-gain stability:
http://www.dself.dsl.pipex.com/ampins/webbop/5532.htm
Maybe thats a clue (different brands handling this feature in a different way)?
Dual op-amps are compensated for unity gain as they do
not have the connections for a compensation capacitor.
Or they are specified to be used above a minimum gain.
The single version is compensated for gains above x3 and
has connections for a capacitor for unity gain compensation.
The dual version does not and is internally stabilised for unity gain.
Incidently the single version uses both of the dual versions
parallel input transistor arrays, this why it has better noise
performance than the dual op-amp.
🙂 sreten.
Do you have any resistance between the output and the scope cable?
The capacitance of the cable loading the output can cause oscillation when in unity gain. When I see this it's usually about 5 MHz.
Putting a 100R in series with the output may solve your problem.
Another thing I've seen is oscillation with the supply wires seperated - twisting them together solves this.
amp_man_1 said:
Hello everybody!
With Regards
AmpMAN:smash:
Try putting a small resistor (100 to 200 ohm) in series with the output. A lot of op-amps will oscillate when trying to drive the capacitance of a cable without some series resistance.
Phil
