stetsom 1k5
hi all i am working on a stetsom 1k5 amplifier.firstly i received the amp with blown outputs(irfp90n20d) shorted,all power supply fets were blown as well.i replaced the ir4427 ic and scoped the signal..got a nice square wave and installed the fets in the power supply.changed the output mosfets along with the irs2092 ic...i think a zener was reading short on the board when i pulled the ic it was reading ok.on powering up i get three blinks on the led at the top.i think its low battery indication it just flashes from power to protect three times then pause then again.i am currently using a 65amp psu at 13.8 volts to start up this amp.
can someone please help with with this one?
