Stetsom 10k ground plane damage
Would you try to bridge an fill in this damage to the edge of the ground plane or not worry about?
The damage is located on the back side of the board around the rectifiers.
David
I don't see it as being an issue. It's not going to reduce the current capacity appreciably and if it's ground, the screws that go through from the other side short the trace to the sink so the bare area isn't a problem.
The vias that are not filled for one of the rectifiers may be corroded. I don't know what the board layout on top is like but if those being open would cause an issue, run a strand of wire through them and solder on both sides of the board.
