just curious to whats the diff, if any, bt 2 channel amp and 1channel?
arent mono amp are internally bridged?
whats the down or upside to havin 2 channel instead of 1 channel to to get the most power out of it, pretend both amp has the same amt of ouput power and using only 1 sub.
As long as the impedance of the speaker is suitable for the capacity of the amp, then you're all set. It doesn't matter if you use 1 channel or 10 channels to accomplish it. 1 channel amps should be simpler, but stereo amps will give you the possibility of use for something other than a subwoofer later on down the line (assuming the bandwidth is good).
