Step-up DC/DC dual Inverter Help
I'm looking for an inverter boost/step-up DC/DC converter suitable for audio.
I must get +/- 12V from 5V for fed opamps.
The chip would be as little as possible, with a little current demand (100 mA at most)
I've seen the LT1945, LT3463 and LT3471 but it seems that it has a ripple of several mV at output.
I'm wondering for a more suitable chips (lower noise)
Thanks in advance 🙂
Can you not just use a 555 at say 30-50KHz and then a DC-DC using just capacitors (no coils)? With no coils present there will be very little EMF. There is another thread where Elvee showed us a very good DC Inverter circuit, which I have breadboarded and works quite well, you only need a step up and a positive side and it's done.
