stator recipe
I built stators out of aluminum window screening and plastic fluorescent light cover. I bonded the screen to the plastic by laying the screen where i wanted it, pressing a hot soldering iron at every junction of the plastic. This forces one or two strands in to the plastic which provides a very strong bond. I believe the screen makes a good material because of its very small hole size, and high number of wires. This shoudl yield a very uniform field strength. Also these materials are low cost and readily available.
the screen doesnt need to be under tention, the spacing is tight enough that it stays flat, also the plastic might bow outward under tention. The screen becomes as flat as the plastic was. Flat enough, but it is torsionaly not stiff at all. When two halves are joined, the structure gets much stronger, and perfectly strong in a good frame. It is important that the screen not be creased.
