starting on this project: confused condenser lens and projection lens.
Hi guys, I'm new here and I'm so confused of how to calculate the size of the condenser lens and .. the factors in choosing a good object lens.
I'm learning a lot lately =).. as a newbie thinking of building a projector. I'm currently looking at the following:
-400w Ballast complete kit
-15" lcd
-norpro bowl as reflector
-a pair of condenser lens of some size (don't know the size)
-a pair of 15" Fresnel
-a triplet projection lense (don't know the specs for this either)
-cold mirror(i'm not sure what size either)
Here's the design i'm thinking of:
(bowl)_(light)_(condensers)_(fresnel)_(coldmirror)_(LCD)_(fresnel)_(projection)
Any thing would be helpful to me at this point. Thanks,
Tuan.
price some cold mirrors
A cold mirror big enough to use after the first fresnel would have to be as big as your LCD. I get the impression you will use a 15" panel, so that cold mirror will cost you thousands of dollars!
Looking at a Rolyn catalog, 100 mm by 100 mm cold mirrors are about $300 each. Figure out a way to use the surplushed $5 4.75" diameter cold mirror instead. You could get several and cut them into squares to tile together, if they were closer to the bulb.
