Standby switch buzz?
I have a bud who asked me to make some mods to his Fender Blues Jr. He bought the deluxe Fromel mods. One of the changes was to add a standby switch to the amp. It was wired in the hvac between tge transformer and the rectifiers. When you switch it from standby to operate he amp lets out a short burst of hum or buzz and then it gets quiet after about 2 or 3 seconds.
I also replaced the filter caps. I'm wondering if one of the caps is leaking? Maybe just as it first turns on?
The guy took his amp home, and he was going to call Fromel to see if they have a clue.
Nothing wrong with the caps, they are just uncharged. It takes them a couple seconds to charge up, and until they do, the unfiltered DC is nothing but ripple - so HUM. In the normal amp, this goes unnoticed because the tubes have not warmed up enough to make sound as this happens. But with the new and NOT NEEDED standby switch, the tubes are all toasty warm and able to amplify when the switch is flipped, and so you get to hear the charging hum.
I have researched the need for the standby switch and totally agree it isn't needed. But it has become a mark of quality in tube amps somehow. I even heard from a boutique tube amp designer who added it to his amp just to be more competitive. But I don't want to insult the guy and tell him it is bull.
I was thinking this was the result of the changes to the circuit too. But I couldn't find anybody else that this happpenee to. It is pretty offensive sounding, so I can't believe nobody else has heard it and complained? The owner is going to call the person who sold him the upgrade kit, Fromel, to see what they say.
I will just wait till he does that.
Some guitarists like to use the Standby as a muting switch. To reduce any potential damage to the tubes, you can place a fairly high value resistor across the switch (say 47k), so that a small positive voltage is still maintained on the tubes to help draw off their space charge and prevent cathode poisoning in the longer term.
Sent from my LG G2 with CM13 using Tapatalk
No, you want to maintain the space charge. Keeping some current flowing is needed to stop a cathode interface layer from forming.
Valves last a long time under two conditions:
1. normal heater, normal or somewhat lower anode current (i.e. switched on)
2. cold heater, no anode current. (i.e. switched off)
The two situations to avoid are:
3. normal heater, little or no anode current (cathode interface layer forms)
4. lukewarm heater, significant anode current (cathode bombardment from positive ions)
A standby switch is quite likely to create one of these bad conditions.
Telling someone the truth when they believe a lie is not insulting them, but treating them with respect. It is disrespectful to think they are so unimportant that it doesn't matter if they believe nonsense. If more guitarists (and their techs?) were 'insulted' in this way then the standby switch meme might eventually die out and then guitar amp valves might last longer.
A standby switch is quite likely to create one of these bad conditions..
I think we're both pretty much on the same page here, and what I'm aiming to avoid by means of the parallel residue is #3. I have always understood (over many years working with valves) that keeping some current flowing means that while the space charge is indeed maintained, it isn't left to remain in a static state close to the cathode, causing an interface layer to form (aka "cathode poisoning").
As I mentioned previously many guitarists like to have the Standby as a mute switch, which I think is reasonable enough. However, there are better ways to achieve that, such as a Standby switch with a bypass resistor, or having a switch which puts a very large bias on the power valves.
BTW your "DF96" handle gives me some great nostalgia, as my first ever valve project, as a kid, was a battery radio, which used a DF96. 🙂
The interface layer forms on the interface between the nickel cathode sleeve and the oxide coating. Nothing whatsoever to do with the space charge. Cathode interface and cathode poisoning are two quite different effects at two quite different places.
The standby switch should sit between the output transformer ht feed and the capacitors...
No, you don't really want to do that, do you? At least, unless your output stage is of Ultra Linear design, or your finals are triodes. In tetrodes or pentodes the screen grids will melt within parts of a second if you cease draining the cathode currents via the plates. Best regards!
I had the owner do a little troubleshooting. If he removes the phase inverter tube the noise goes away completely.
The problem I am having with the explanation so far that it is just the B+ charging up, is that tons of others have done this same mod to their Blues Jr., and nobody has ever heard of this noise before?
I just heard from him and he said that hooking up an attenuator made the noise go away?
