I have two minidsp modules (2 x 4's). I use one for a 2 way speaker and would like to connect the other so that I can add a sub (and use the Parametric EQ to smooth out the room modes).
I have looked through the manuals but cant find a clear instruction on stacking 2 minidsp's. Hoping someone can give me some guidance.
I purchased the 2.1 way crossover advanced plug-in, thinking It allowed 3 crossover points (2 way stereo plus 1 mono sub) but it seems to be just a 2 way crossover. Do I now need a 3 way plug-in to make this work?
Solved. Good info can be found here if anyone else needs it:
http://www.hifizine.com/2010/12/prototyping-4-way-open-baffle-speaker-with-the-minidsp-2x4/
@ Dabbler,
There is no explanation in the user manual on how to stack 2 miniDSP since it's not possible to do control them together. Easier in your configuration is to build a system with the 4way plug-in if you want to control your Left and right speakers in a 3way like configuration.
Hoping this info helps.
DevTeam
DevTeam
