I need help modifying a circuit i obtained from the accutronics site. I want to ad a mix (wet dry)potentiometer and a reverb bypass switch that can be operated from the front panel and foot-switch.
I have found a switch module made by
Click-Less? True-Bypass Switch - Jack Deville Electronics and/or AMZ True-Bypass Retrofit
the problem being that i have no idea where to insert it into the schematic attached
Thanks for reading.
Cheers
Thanks for reading.
Cheers
You don't want to insert it in the driver/recovery circuit. The "mix" pot should go between the two points where that circuit connects to the amp. Otherwise, you'll be mixing in the pre/post EQ of the reverb, not the true 'dry' signal. The "bypass" should come after the recovery stage so you're not adding any noise from the reverb when it's not on.
