I'm looking for a 6GH8 model.
Does anybody have one.
I already have 3F4, Duncan, Koren, Marshall, Pspice, but they may be older revs.
Also, I have a model for a simple 3 leaded pot, but would like a 4 or even 5 leaded tapped pot for loudness contour ckts
Thanks guys.
Thanks guys.
As its a triode and pentode there won't be. Best thing is to find something similar to the triode and something similar for the pentode and use those.
The pentode looks similar to a 6CB6 which is in the tube models. There may a better match. Hope this helps.
look
Koon posted the models here:
https://www.diyaudio.com/community/threads/vacuum-tube-spice-models.243950/post-5597718
There are plenty of triode-pentode models, for example ECL86 and the likes, split in a triode and a tetrode model.As its a triode and pentode there won't be. Best thing is to find something similar to the triode and something similar for the pentode and use those.
If close isn't good enough and there's no model you could look at creating your own.
https://www.dmitrynizh.com/tubeparams_image.htm
http://www.normankoren.com/Audio/Tubemodspice_article.html
Another option is to start with the 6EA8 model and somewhere on diyaudio there's a LTspice curve tracing program. Adjust the params until your happy with the fit from the datasheet.
I have done this for a KT120/KT150.
- Tubes / Valves
- Spice Models
