Spice Model for Toshiba TTA1943
Hello to all.
I am designing a Class-B power amp, and I will use Toshiba pairs TTC5200/TTA1943 as output transistors. Whereas Toshiba offers a Spice model for the TTC5200, it doesn't for the TTA1943.
Does anyone have Spice models for it, or for both? Should I look for Spice models of 2SC5200/2SA1943 instead?
Thank you in advance.
The TT prefix indicates manufacture in China. I understand that both sources now use the same size dies, so the same current 2SC5200/A1943 models should apply to either marked types. There are also 2SC5200N/A1943N types which refer to TO3P package variants but also use the same dies.
Actually, no, all the transistors I got have JAPAN written on them.
Dear DimBax,
I have designed/simulated/build several amplifiers using those power transistors. Here you can find all necessary informations to simulate and build your class AB...
2stageEF high performance class AB power amp / 200W8R / 400W4R
The TT types are mostly the same as the 2SC5200 and 2SA1943 but are cob and hfe selected.
BR, Toni
Dear Toni,
Thank you very much. I have seen your thread before, congratulations on your builds, really nice work. I will do my simulations with the models you mentioned.
Best regards,
Dimitris
