What the heck are those black things attached to the out put of the power supply? They sale speed of light by virtual dynamics.
https://positive-feedback.com/Issue19/virtualdynamictestament.htm#:~:text=The "Speed of Light" technology was created to,field than the ones generated within the circuits.
The above is to do with cables, but Virtual Dynamics uses magnets to create a stronger magnetic field than the ones generated within the circuits?
Are they expensive? Are they effective? It was already installed inside a KST-150. I was wondering if it was a upgrade or if it came stock with those.
I read that Virtual Dynamics used magnets in power cords with the objective of speeding up the flow of energy.
Thanks for the info. I was planning on selling the amplifier and I wanted to know if I should mention the seed of light technology or not.
Some quotes regarding Virtual Dynamics' "Speed of Light" technology:
"Virtual Dynamics certainly stands apart from the crowd. Its cables incorporate several proprietary technologies, which were revealed to their chief designer through the power of prayer."
"The company claims that its Dynamic Filtering damps vibration from the conductor by using specially designed spheres or particles as a mechanically based circuit."
"The David power cord, which retails for $550, employs the same Speed of Light and Dynamic Filtering technology as used in the speaker cables."
https://www.soundstagenetwork.com/revequip/virtualdynamics_david_cables.htm
They are complete BS. Up to you whether you tell the buyer!Thanks for the info. I was planning on selling the amplifier and I wanted to know if I should mention the seed of light technology or not.
At least it's a good laugh.
Years ago, I even saw an anti jitter spray...
Without forgetting the famous Blacklight CD's , it goes hand in hand with those who want to sell you supernumerary energy...
They are little cylinders of snake-oil... Complete woooo
Speed Of Light
How it works
Transformers and other internal components create electromagnetic fields that degrade the audio signal.
Via powerful permanent magnets, Speed of Light (SOL) uses a specialized circuit to set up a forced magnetic field stronger than the electromagnetic fields formed in the circuits of the components. This cancels any detrimental effect on the signal.
Highly concentrated magnetic flux lines deliberately laid onto the conductor promote the flow of electricity. Inductance (AC resistance) is dramatically reduced by SOL and more power is allowed to flow into the system, thereby increasing throughput of the connected components.
We are convinced that Speed of Light increases the efficiency not of the component, but of the energy itself. This allows a system to achieve levels of playback not possible without Virtual Dynamics Speed of Light cables.
https://web.archive.org/web/20060827025304/http://virtualdynamics.ca/tech/Speed Of Light/
Sounds like electrons lubricated with snake oil to me 😆
How it works
I love it. Inductance is AC resistance. Back to school for you!
And exposing a wire to a magnetic field reduces the inductance of the wire and allows more energy to flow.
This may be a side-effect of Canada legalizing cannabis, lol.
Magnets must be made out of magnetic materials and they will increase the AC inductance of the wire that they surround
Looks like they went out of business before that happened.
dave
- Speed of light technology
