Special price for pretty miniature TA2024 Class-D apmlifier
In my personal point of view, this is one of the best small class d audio amplifier I've ever use. Although the power is only 15W, it's lound enough for desktop. The background is very clear and the sound quality is excellent, much better than another class D of VMA2015. The case is very beautiful and the knob move smoothly. When open the case you can see a lot of hifedity audio components well arranged on the beautiful blue PCB. If you are looking for a small, low cost, good looking and sound quality amp for your desktop soundbox, this is second to none!
The price should be $49 but now only $38
Here's the link:
Miniature DT0118A 15Wx2 Class D audio amplifier (TA2024) - Boards | Kits | Components | Modules | Tools
Description
This is a well designed and built miniature 15Wx2 class D audio amplifier. It use TA2024 as amplifier IC. Components are selected carefully to achieve the best sound quality. Beautifyl made case, compact size, powered by single 12V, these features make it a ideal choice for desk top sound systems.
Featues
- Designed with TripathTA2024
- 15Wx2 output power @ 4Ohm load
- Powered by single power supply
- 0.04% THD+N @9W 4Ohm
- 88% effeciency
- Black anodized silkscreen aluminum enclosure
- Black anodized silkscreen aluminum front and rear panel
- Blue LED power indicator
- Big metal voice knob
- Very compat size only 107mm x 75mm x 27mm
Product images
Overall View
Rear Panel
Front panel
Inside the case
Hifi quality components
