Hi folks .. I've been a member for a couple of years now but this my first time writing anything ... I have a question I have some pa boxes without the mesh grills ..does anyone around the Sydney area
know where I can get some perforated or expanded mesh type speaker grill mesh from. ...any help would be greatly appreciated as ...I just can't find anything and need to finish my project ...thanks folks
This is what I found online - see if this helps:
https://www.wagneronline.com.au/speaker-grilles/speaker-components/audio-speakers-pa/3121/fl/
We have a Beyma distributor nearby that carries Penn-Elcom products.
They have all sorts of hardware for speaker building. I usually buy grilles from them.
If you'd like to cover the entire face of the loudspeaker, google "hardware cloth". It's what I'm considering using to replace some PA metal grills. I may put home audio speaker grill foam between a front and back layer of the hardware cloth.
If you use acoustic transparent foam (ie 3 mm thick) to cover the grill from the outside, you can use a grill that doesn't look that great itself. Wire mesh grill in sufficient sizes is often used by people that want to customize their car looks. It often needs some "3D-forming" (like bending/ rounding) to get up to the desired strength for speaker grills though.
Johan
Johan
