Speaker Wholesales/Manufacturer
Does anybody know of any manufacturer/wholesaler that I can purchase speakers in quantities of 100 - 200 pcs. at a time? I am looking for a full range 4" driver that will fit into a product that I am thinking of manufacturing. The driver should be of reasonable quality (not junk), but also at a reasonable price.
Thanks to anyone that can help.
N
The speaker I need should be a full range driver. The one that I am currently using was discontinued, but the specs are as follows:
~Paper cone, rubber surround
~Power Handling 10W RMS/ 15W max
~Freq. Range 75 - 20,000 Hz
~Impedence: 8 OHMS
~Fs: 105 Hz
~SPL 86 dB
~Dimensions : 4" x 3-11/16" x 2-1/4"
I would prefer a speaker with higher SPL, and rated at 4 ohms, but beggers can't be choosers.
Also, I would prefer a round 4-1/4" round frame. The one I was using had a square frame that I had to grind down in order to use.
Thanks again,
N
I already checked Parts Express. That is where I was buying the last one I was using. They don't have anything that I can use (for the right price).
The reason for the tight price point is that I want to keep final product pricing low.
Not sure about the price point, but Adire Audio sells primarily to the OEM market. Maybe they have an OEM driver in production that fits your criteria.
http://adireaudio.com/OEM/Drivers.htm
edit: Looks like they do small quantities as well, " With extensive production capabilities both domestic and abroad, we can supply your driver runs from as small as 12 to over 1 million units a year. (from Adire website)"
