Speaker protection with capacitor
I have been building some amplifiers. All are prototypes (the build, not the components quality), so I don't have the gut to fire my main speaker. I don't need to listen for long, but I need to listen with good speaker (I surely need the transmision line to value it's lows).
So I have this idea, I will protect my main speaker simply by putting a 6800uF cap at the output. I have no problem with the effect of the cap to the sound. But will this work? What should be taken into account to sufficiently protect the speaker from all kind of amplifier failures?
Not sure whether a cap that big will give your amp a hard time, but it should protect your speakers against DC faults. Have you worked out what the corner freq will be of the crossover that the cap will create? (ie at what point it will roll off your bass).
In order to protect against excessive power dissipation you could use some of these http://www.jaycar.com.au/productVie...d2=&pageNumber=&priceMin=&priceMax=&SUBCATID=
I hadn't thought of using them for amp testing before, but I think it is an excellent idea. just choose a trip current that is within the range you want to test and you should be safe. If the cap is ok then combined with a polyswitch, I think you should be covered.
On second thoughts if your amp puts out a lot of energy only at high freq you may still fry your tweeter, as it could get say 50W and only be rated say 15W. When I have used polyswitches for speaker protection I choose a suitable one for each driver 🙂
edit: and make sure the cap is of sufficiently high voltage too 🙂 probably minimum of 50V depending on the max power of your amp, 50V should be more than enough for 100W... and I think it should be a bipolar...... can you get bipolar electros that big??
Tony.
Thanks Tony, Richie. I will follow that link shortly. I don't know about the polyswitch, I hope it is a simple thing...
I picked 6800uF because I felt that it is just enough for 20Hz. Not quite sure with the real thing. The voltage ratings are 160V/200V/400V. And yes bipolars.
Now that richie00boy mentioned it, I have a confusion regarding these terms: BP, NP. If I connect both negative ends, what is it gonna be? If I connect both positive ends, what is it gonna be? What is the difference between them (I found that certain connection is soundwise better than the other in certain circuit)
If a NP can be made by connecting 2 polar caps, the resulting NP cannot pass DC correct? How about conventional NP like Black Gate N? Shouldn't I use it for DC coupling in pre/amps? 😕 😕 😕 (Hint: GC!)
So that what a polyswitch is 🙂 🙂
I don't have an online purchase privilege, but it reminds me of a primitive approach. Yes, a fuse! 😀 But not sure with the proper rating for that.
And the polyswitch looks like a cap for handling a very high frequency. Now I remember the oscillation issue of a failing amplifier, may be shorting the tweeter's legs with silver mica 5nF will help? 🙂 Well, I think I can rely on the coupling cap alone for protection, after running at least 1 hour on my bookshelf 😎
the polysiwtches work great for protecting against clipping... I used to take my amp and speakers to parties a lot, before I put polyswitches in I blew a LOT of tweeters, and mid ranges. After the polyswitches not a single failure 🙂 many years later when doing some amp testing I found that the point above which the tweeters would blow, just happened to correspond with the point the amp started clipping 🙂
and yes it is pretty much an auto resetting fuse 🙂
Tony.
Tony, I think I have misunderstood you and richie00boy 🙁
I just remembered the way a cap blocks DC is by fact that DC is a very low frequency (or no phase change to allow for discharge). I thought that you mentioned BIPOLAR as having positive and negative poles to be able to protect DC. But I guess Bi-polar is not 2-pole capacitor right? Rather, it is quite similar with non-polar? So the question is, why it has to be bipolar??? I'm more confused now 😀
I believe It's basically because if the amp develops a fault (putting out DC) you won't know whether the DC will be +ve or -ve on the amp side of the cap.... so if you put in polarised there is a 50% chance it will explode if the amp goes into a dc fault state 😱 if you use bipolar it doesn't matter 🙂
Tony.
Jay said:
Oh I see 🙂 So I need to use 2 caps. But to avoid problem with lows cut-off I need huge capacitance! (My PSU caps will ruin the sound. But those 6800uF/200V caps, if sufficient, are very musical 😉 )
Stick your two 6800 caps in series, + to + with one - to amp output and the other - to speaker. That'll give a -3dB point about 6Hz with an 8 ohm speaker.
Buhl said:
The cap does not need to be bipolar ! - just point the "-" towards the speaker, and the "+" towards the amplifier - my Nelson Pass Zen4 amp uses a ordinar 10000uF/50V polar electrolytic cap. bypassed with a small PP cap in the output to protect from DC.
And that works because you haven't yet had a fault to protect from. Think again, what happens if the amp outputs a large negative DC voltage?
Hello Christer
This is true - in my case my amplifier runs of a 0-50 volt supply, hence it will never put out a negative voltage - I forgot that if using + and - supply, this could result in negative output on faliure...... back to back with the polars, or bipolar is the way ! 🙂
Cheers !
Buhl
If the amp has a single rail supply it already has a capacitor-coupled output and is inherently safe as far as DC-to-speaker is concerned.
If it has + and - rails it needs non-polarised cap or a back-to-back pair. You can't pass AC through a normal electrolytic, it will go bang whether or not the amp goes DC.
