hey, im wondering if you cuold suggest some circuits that protect speakers from dc. ive made some diy amp and i want to add some kind of protection circuit to it that does not require its own power supply. any ideas are welcome
Loudspeaker Protection and Muting
if you buy his PCBs, the PCB version is much simpler and still does not require additional supplies.
In general, DC offset protection circuits monitor the DC level across the speaker terminals. The circuits generally have a resistor connected from the active speaker terminal to a capacitor. During normal operation, the capacitor remains discharged because the resistor is constantly charging and discharging the capacitor as the waveform swings from positive to negative between the rails. When there is a DC fault, the resistor is able to charge the capacitor because the voltage goes from be AC (normal) to DC. When the voltage across the capacitor reaches a certain threshold, it triggers the shutdown circuit. For car amps, the most common protection circuits shut down the power supply.
There is an IC that's been used in many home audio amps that could be used in car amps (and may have been used in some of the Japanese amps). It's the UPC1237HA. The datasheet has a sample circuit.
