Speaker Protection and Dummy Loads
Joined 2013
I’m in the process of setting up a tube amp testing bench, and have built an 8ohm dummy load with BNC connectors to connect an Oscilloscope. Before hooking up anything “important” I thought I would test the dummy load with a cheap chip amp, but this amp has a built in speaker short circuit protection. Hooking up the dummy load on the speaker terminals seems to trigger this protection circuit, which was not what I expected.
I’ve verified that there isn’t a problem with the other connectors attached to the dummy load (the oscilloscope) by taking another 8 ohm resistor and hooking it up across the speaker terminals directly, with the same result.
Since this isn’t what I expected, I thought I would appeal to the collected wisdom just to get some feedback, before hooking it across an expensive output transformer. Have dummy loads been known to trip protection circuits?
