Good day my good sir... We have a regular gig in a resort, Can you give us an advise how to position my two Mackie speakers (SRM 450) and two B3 (ES215a) in a Covered Court (rectangular space can accumulate up to 100 persons) open space and I have three singers without having a feedback. I also use Behringer mixer xenyx x1222 usb and 4 wireless mic only...
I positioned the Mackie 5ft above the floor both side of the dj 5 meters apart side the dj and the B3 below the Mackie speakers both side also...
Is this correct? 😛
Hopefully you can give me an advise...
Thanks, more power 😀
Is this correct? 😛
Position of Beta Three SigmaE215a is wrong, it must be mounted higher up.
If the BOTH of the woofers of SRM 450 and Beta three SigmaE215a are above the heads of the audience, everything is OK.
You don't need 4 speakers for 100ppl on a deck, based on the specs I'd suggest the B3's on stands at about 6ft in height on either side of the stage area, and make sure all singers are behind these speakers. If floor monitors are needed use the Mackies but otherwise leave them in the truck.
