I have the following for sale:
Pair of NEW Pro 12" Woofer Drivers # KW12002 (Same Manufacturer of the Drivers used in Emerald Physics new EP Series). Note: I was Lead Designer ( Crossover / Driver Spec. for the EP Series). 95 dB efficiency / Paper Cone / Dual Surround /10 lb Magnet Structure / 2.5" Voice Coil / >20lb total weight each driver
Expensive to ship.... Pair - $150USD + $50 shipping
4 qty NEW Wavecor 7" Woofers Model WF182BD04; Coated Paper Cones / 39mm Voice Coil
Built like / or better than a Scanspeak Driver
$375 USD with Free shipping
2 qty Slightly Used 30mm Wavecor Tweeters Model TW030WA05 - 4 ohm
$99 USD / pair with Free Shipping
4 qty NEW Peerless SDS Series 5-1/4" Coated Paper Mid - Bass Woofers Part # P830656 / S134WR2608 (10/10)
$99 USD for 4 with Free Shipping
4 qty NEW Peerless Neodymium 1" Dual Ring Tweeter in small 65mm faceplate Part # XT25SC-90-4 (10/10)
$95 USD for 4 with Free Shipping
Used Tang Band 6" Neodymium Subwoofer (6/10) . Note Center caps is cosmetically not perfect
$45USD with Free Shipping
Used Pair of Foster / Pioneer Radial Horn Tweeter ( from Audiosphere Speaker)
(7/10)
$40USD with Free Shipping
Used Pair of E-Cube 10uF 100VDC Film & Foil PP Capacitors Thiel used E-Cube caps in 2.7 /3.7 Series
(7/10)
$30USD with Free Shipping
3 lbs of Acousta-Stuff Premium polyester speaker enclosure fill
(8/10)
Free to anyone purchasing $100USD
For the FOLLOWING I prefer to sell as a LOT for
$79USD with Free Shipping
Binding Posts:
3 NEW Binding Post - Gold Extended Length RED (WBT Type)
3 NEW Binding Post - Gold Extended Length BLACK (WBT Type)
2 Slightly Used Binding Post - Gold Extended 10 Ga Length RED
2 Slightly Used Binding Post - Gold Extended 10 Ga Length BLACK
NEW Speaker Driver Connectors:
28 Black Female 0.110 16/14
3 Red Female 0.110 16/14
35 Red Female 0.205 16/14
10 Black Female 0.205
NEW Heat Shrink:
10 ft Heat shrink 2:1 3/8” RED
10 ft Heat shrink 2:1 3/8” BLK
10 ft Heat shrink 2:1 1/2” RED
10 ft Heat shrink 2:1 1/2” BLK
NEW Ring Type Connectors:
3 Red Ring Type #10 12-10
3 Black Ring Type #10 12-10
Paypal for payment in US and also Interac E_transfer in Canada
Shipping to US / Canada
(7/10)
(7/10)
(8/10)
Binding Posts:
NEW Heat Shrink:
