This seems like a stupid question since it should be straight forward, but i'm prepping for a small amp build and was just configuring the rear plate of the chassis.
I was going to install the speaker binding posts but was confused, maybe I bought the wrong ones? This is what I bought..
http://www.partsconnexion.com/product9694.html
My question is, how the heck do you isolate the posts where they go through the back plate and into the chassis so as to not touch the aluminum?
The black pieces that come with it are completely flat on the back, no nipple to insulate against shorting the aluminum to the through hole.
I can always drill the hole substantially larger then the actual diameter of threaded portion of the post but unless it is loctited/epoxied/etc, there is always a chance it could possibly slide/move when at attaching speaker cables and short.
So did I buy the wrong posts (they all look the same)? or am I going about this the wrong way. Any help would be much appreciated.
Maybe ...wrong mounting by the operator ? The isolators must allow to ...isolate ! No risk must be allowed , so it must be an error in the packaging chain , as I don't think ,like you , that the couple must be flat .
Ask also at info@partsconneXion.com😛
You could use a short piece of heatshrink tubing or you could PM me your mailing address and I sendl you a couple of shoulder washers (inside 1/4", drill hole 3/8"). E
thanks for the offer mickey. Before I put you through the trouble of mailing, is there a local place that might sell these shoulder washers?
Where in the "Great White North" are you? Generally, you buy 100, so: nope! E
ps: I can afford to spend $0.59 postage plus the envelope
Another cheap, possible solution could be to insulate the metallic portion passing through with Teflon plumbers tape. Available at any decent hardware store for less than a buck. The stuff is useful for doing many things (especially making cables).
Could be a total solution, or a adjunct to other solutions you are looking at
- Design & Build
- Construction Tips
- Speaker binding post installation.
