SPDIF to I2S Converter Group Buy
All,
I have designed an SPDIF to I2S converter based on the CS8416 in hardware mode.
It supports up to 24 bit / 192kHz, while automatically adjusting to all standard sample rates and 16 / 24bit operation.
It can come in two varieties:
1. It can be powered from 17 to 72V and provide an auxiliary PS with 12V 800mA output.
2. In can be powered from 6 to 28V and provide no auxiliary PS.
The board also has a feature to bypass the I2S from CS8416 with an external I2S bus. When SPDIF is not present the secondary I2S bus is routed to the output.
Prices as follows
$200 if 10 people purchase with 14-72V input
$150 if 20 people purchase with 14-72V input
$130 if 30 people purchase with 14-72V input
$170 if 10 people purchase with 6-28V input
$120 if 20 people purchase with 6-28V input
$110 if 30 people purchase with 6-28V input
PCBs are high quality 2 layer boards with ENIG finish and use only high-quality components. Boards are manufactured and assembled in Canada.
See attachments for board sizes and pictures. Dimensions in mm.
Thanks for your time.
Leo
