I wanted to add digital input to my sony xa7es player. Its digital filter chip uses 16bit right justified msb first data in a 24 bit EIAJ packet that comes from servo chip. word select is inverse of philips format a usual. DIR9001 gives some sort of eiaj data, but I could not solve if it gives the correct sony eiaj data, here the first 9 bit period cary msb data as a whole, after that the last 15 bit fill the rest of the 24 bit pack. On th other hand sony uses 48fs BCK signal from servo to filter chip, this is unavaliable from any receiver chip. Do you have any solution for this? I see this sony eiaj is standard output from many digital traking focus servo chip, but there is no spdif receiver that outputs this.
Regards,
Mesut B.
Regards,
Mesut B.
