spdif digital out
You have to make sure your motherboard has that 3-pin header first, if it already has SPDIF-out on the back panel it likely won't have another header.
And BNC... if the point of using this is for the 75 ohm, the short distance on the connector is nothing compared to the wire leading to the mainboard which isn't 75 ohm anyway.
