Spare parts wanted for old AWA Audio Test Equeipment
Hi All;
I'm resetting up my Electronics workshop and in the throws of buying test gear - for Tube Amp work. I have an old AWA F242A Noise & Distortion Set, an F240 Noise & Distortion Set and a G231 Audio Oscillator. I also have a dual trace BWD 539 in nice condition which still works.
None of the AWA gear is in great physical condition. One of the Noise & Distortion Sets had been most likely dropped and needed a little cabinet panel beating. The other 2 items look as if they have had a grinding machine run over the panels and scuff both the tops and bottom panel. ( But what do you expect buying "bargains" off EBAY ! )
Would anyone know of any sources of spare parts for these AWA units in particular ?
Black, White & Red push buttons, cabinet screws, Knobs, feet, side handles and that sort of stuff for the AWA gear is required. Electronically I also need axial electrolytics, but that is not such an issue.
Failing this, - I might have to buy a second machine just to build one good unit from two wrecks. Not the cheapest option.
Any assistance would be appreciated.
Note - The pictures are for illustration purposes only.
