SP-14
It's a mod made by Don Sacs. The mfr doesn't comment on this mod. And Don won't comment either. This mod has been talked about on this forum before. Just waiting for someone who has done this mod before.
Well, a quick look at the rectifier data sheets shows a slightly incompatible pinout, and the fact that the 6BY5GA draws 1.6 amps of heater current vs 0.6 amps for a 6X5 may explain why nobody's talking about it. Maybe the stock power trans can't handle the extra current?
jeff
Reactions: rayma
Run 6X5GT or 6BY5GA Rectifier
Try this link above on the search forum on DIY Audio as It well spells out the procedure, I have not done it yet myself as I am busy doing my house then speakers then this preamp. The transformer I have is rated at 2 x 2.5amp so may even try two 6By5 or one for each channel. All the best.
Thanks. I have a general idea of the mod. I saw that post as well. I just can't figure out if the two R-FILLS are bridged. The OEM build shows one bridge/one resistor. I'm trying to nail down the exact way to do it. Thanks again. Ian.
