SOYO SY-P4I845GV ISA Plus Motherboard NEW
Do you use an LMS, MLSSA, or older AP system that requires a computer supporting ISA cards? They are NOT easy to find and many times will limit the CPU to something like a 386 or 486. This SOYO motherboard supports socket 478 Intel Pentium 4 CPUs, allowing you to run Windows XP AND use your measurement hardware without issue.
This motherboard is new and was purchased as a backup for a system in daily use. It comes complete with the original driver CDs and cables.
These boards are no longer available and I'm asking $200, plus shipping from Toronto, Canada.
Please feel free to contact me with questions.
Thanks!
Features:
SOYO SY-P4I845GVISA Plus pushes the envelope by hiking FSB from conventional 400 to excepional 533MHz for the support of the latest Pentium 4 Prescott CPU, extending the life span and compatibilty of more economical and affordable Intel 845 chipset. In addition to its comprehensive support USB 2.0, ATA100, 6-channel AC' 97 CODEC, and PCI slots, the 3 onboard ISA slots are extensively tested for compatibility with legacy ISA devices and prolong their life circles. SY-P4I845GVISA Plus provides immearsurable value to the integration of obsolete devices with state-of-the-art Pentium 4 CPU & OS, a true ELIXIR for ISA.
Product Specification:
Processor Type: Intel Pentium P4 / Celeron / Celeron D Socket 478 CPU with 533/400 FSB
CPU Interface: Socket 478
Graphics Info: Intel Extreme Graphic supports DirectX 8 & Open GL 1.1, rendering realistic animated and static 2D/3D graphics and sharp text quality at up to QXGA resolution.
Chipset Description: Enhanced Intel 845GV & ICH4 Chipset support Intel Pentium 4 / Celeron Socket 478 CPU with FSB 533/400MHz, DDR 333/266 SDRAM, USB 2.0, ATA100/66, PCI
Chipset Type: Intel 845GV
System Memory Description: Non-registered and non-ECC DDR 333/266 SDRAM
Expansion Slots: 4 * PCI slots
3 * ISA slots
2 * DDR SDRAM memory slots
2 * IDE slots
1 * Floppy slot
IO Description: 6 * USB 2.0 ports (2 on back panel, and 4 by onboard pin-header)
1 * 10/100 LAN port
1 * LPT port
2 * RS-232 port (1 on back panel, 1 by onboard pin-header)
2 * PS/2 ports
1 * Audio Jack (Line-in, Line-out, Mic
IO Connections Description: Realtek ALC655 6-channel AC` 97 Audio CODEC
Realtek RTL8100C 10/100Mbps LAN Controller
IDE Description: 2 * ATA 100/66 IDE slots connecting up to 4 IDE devices
OS Compatibility:
Win2000
Win98
WinME
WinXP
Linux
FreeBSD
Package Content: 1 * SY-P4I845GVISA Plus Motherboard
1 * IDE Cable
1 * FDD Cable
1 * Back Panel
1 * Driver CD
1 * Quick Start Guide
