Source for replacement (neon) bulb for power lamp on HH Scott 99D?
Hello.
Would anyone know where I would be able to get a replacement bulb (called neon lamp in the service manual, but no part number) for the power lamp on an HH Scott 99D amplifier? I have some LEDs, but the voltage across the connections for that bulb seem pretty high.
Thanks in advance,
Les
Any major electronics distributor will have common neon lamps (probably it's an NE-2).
These run on over 90V and use a large series resistor, so using an LED would be a complex substitution,
perhaps having to run off the filament supply, rectified.
Are you sure the lamp holder can be opened to replace the NE-2? It could be sealed, which was common.
