Now for my 1millionth question 😛
A few of you are from Calgary, so you might be able to help me with this, where can I get perforated Metal in this town for relatively cheap?
And how much is cheap?
There may be Metal Supermarkets outlet in your town of Calgary and they usually order perforated metal from here: http://www.diamondman.com/index.html
McMaster will ship to Calgary if you can't find it elsewhere: http://www.mcmaster.com/ This is the cheapest source of perforated metal I've been able to find.
let your fingers do the walking
Try the yellow pages. Sheet metal, perforated metal or expanded metal. A couple of calls and a few requests for direction ought to get you where you need to be.
If you plan on insulating the perf metal I would suggest you check out the pages under powder coating and see who will coat the sheet with nylon. There should be a number of shops happy to do so. Keep us all posted as to how things work out. Regards Moray James.
MrPin said:any idea how much I would be looking at Persheet?
IIRC it was $150 per 4 x 8 sheet (1/16 thick)
- Planars & Exotics
- Source for perforated metal in Calgary
